Results 1 to 3 of 3
    May The Force Be With You
    Reputation: shwinn8's Avatar
    Feb 2006
    test
    I received the master cylinder and this little metal pin was in the bag. looks like it goes into the empty bleed hole. if so, how do i get it in there without damaging the lever casing?
    '11 Jedi
    '01 Rocket 88 Stage3
    2008 Toyota FJ Cruiser
    That plug you have is for the old Nine & Sole disc brakes abnd won't work with your lever assembly. There are two T10 screws for bleed ports on that lever, and it looks like you need to get one if not two of them. Take it back to the shop with your receipt and they should be able to help you out.
    You are not what you own.
    Feb 2006
    thank you for the reply, only needed one bleed screw. i ended up getting one off of Universalcycles.com along with a caliper rebuild kit
    '11 Jedi
