Results 1 to 3 of 3
    Hayes Stroker front brake problems!
    I just got a new bike with Hayes Stroker brakes and the front brake doesn't have any pressure at all. The caliper does grab the disc but there is a lot of drag (won't spin freely). has anyone had this problem or know how to fix it? I reset the piston in the caliper and still don't have anything to work with. I need help.
    I'm guessing that your new bike did not come from a local bike shop. But if it did, obviously you need to take it back there. Otherwise, I suggest that you email Hayes about the problem. I had a problem with some Hayes Stroker Trails, and they were extremely helpful. Check the Hayes website and you'll find their tech support email address.
    Reputation: vk45de's Avatar
    If by no pressure you mean mushy lever feel, that's the classic sign of air in the system. See if a good bleed won't cure it.
