    Hayes Stroker brakes grabbing
    My front Stroker brake tends to grab. Is this typical for Stroker? Any solutions?
    Reputation: EGF168's Avatar
    What size rotor are you using? If you have a big 7 or 8 inch rotor then try downsizing to the 6in rotor!
    Do you have the Stroker Ryde’s or the Trail’s, the Ryde’s are pretty poor brakes and nothing compared to the Trail’s, especially when it comes to modulation. The grab on the Ryde’s will feel pretty vicious, dangerously vicious as some people have said…
    They are the Trail model. I'm using a 7 inch rotor. I'll reduce it to 6 inch, which won't reduce my stopping much. Thanks.
    Quote Originally Posted by EGF168
    ...idios...
    Reputation: SteveUK's Avatar
    Have you tried different adjustments to the throw of the lever? The position of the lever blade relative to the bar can make a considerable difference to the feel of the brake and is often overlooked when setting brakes up.
    Diogenes
