Results 1 to 7 of 7
    Jsgolfer
    Hayes Sole - Shimano XT Swap
    I purchased the Shimano Deore XT brakes that everyone seems to rave about. They are replacing the Hayes Sole that came on my 2006 Giant Anthem. Question, is it a simple replacement or will I need adapters? Also, are new rotors a must? Thanks!
    Ho'lier than thou
    Reputation: Katz's Avatar
    Quote Originally Posted by jsgolfer View Post
    Depends on the type of So1e you have. Some So1e calipers bolted directly to the frame/fork, like the pic below. In which case, you'll need adapters.
    Otherwise, there's a good chance you can simply unbolt So1e calipers and bolt on XTs to the existing adapters (unless you want to change the rotor diameter).
    IMO, no. I'd scuff the rotor with 180~220-grit wet/dry sand paper and clean them with alcohol, just to get rid of any glazing.
    Jsgolfer
    the links your supplied did not work.
    Jsgolfer
    how do i know which adapters i need and where can i get them?
    Jsgolfer
    I plan on running a 180mm rotor up front and 160mm in the back. does that help?
    B A N N E D
    What fork do you have ?
    Are your current brakes IS mount or Post Mount ?
    What size rotors are you currently using ?
    180mm rotor on the front:
    Post mount fork = SM-MA-F180P/P2 adapter
    IS mount fork = SM-MA-F180P/S adapter
    160mm rotor on the rear:
    IS mount frame = SM-MA-R160P/S adapter
    * If you have already have a post mount caliper on the rear and use a 160mm rotor then you won't need a new adapter.
    I thought that those tech docs that I put up earlier had adapters on them but they don't, the following docs show the adapters.
    http://techdocs.shimano.com/media/te...9830667774.PDF
    http://techdocs.shimano.com/media/te...9830670737.pdf
    http://techdocs.shimano.com/media/te...9830670738.pdf
    http://techdocs.shimano.com/media/te...9830693993.pdf
    Adapters are sold in lots of shops and are very easy to find.
  1. Hayes Sole
    By Mitch1171 in forum Brake Time
    Last Post: 04-18-2012, 02:53 AM
  2. Hayes Sole Problem
    By dk11 in forum Brake Time
    Last Post: 11-30-2011, 09:38 PM
  3. Hayes Sole or BB5?
    By Shooter98 in forum Brake Time
    Last Post: 10-18-2011, 04:42 PM
  4. Upgrading from Hayes Sole
    By dmgthe2nd in forum Brake Time
    Last Post: 05-22-2011, 08:37 PM
  5. hayes sole question
    By jekyll600 in forum Brake Time
    Last Post: 01-06-2011, 10:43 PM
