Results 1 to 2 of 2
    C.J
    C.J is offline
    Hayes sole brakes
    Hi all.
    Right, After I blead both brakes the other day I went out for a test ride and the first time I touched each lever some fluid came out of the breather holes (at this point the brakes were biting halfway through there span, which is how I like them).
    This continued to happen every time I touched the levers untill the brakes were biting quite close to the bar ( I couldnt lock the rear wheel on gravel for example).
    The pads are fine by the way.
    I was just wondering what would make them better, I was thinking of fitting braided lines?
    Thanks, Chris
    C.J
    C.J is offline
    Any ideas guys?
