Results 1 to 7 of 7
Thread: Hayes ryde
    idigscars
    Hayes ryde
    I'm having all sorts of issues with these brakes. I ordered a complete bike from Jenson. The rear brake seems to have no power at all, and the front brake lever has no play in it,. curious if there is anything I can do. Any suggestions welcome.
    Reputation: casrec's Avatar
    Aug 2010
    Quote Originally Posted by bome View Post
    I have hayes Ryde on my stock KHS Velvet. I think they are great breaks for the cost and might not have the greatest stopping power but do stop me quickly when I want to. I am actually going to put up a post about improving stopping power. But no power at all seems like something might be wrong. I would have them bled again and also clean the back rotor to make sure there is no packing grease from the chain and rear cassette on it. My back rotor had a little packing grease on it when I first took the bike out of the box. I would consider bleeding them again though or take it to a shop if you are not familiar with that.
    No advice for you really, other than rebuilding them and figuring out what's wrong. They should work fine, like mine do.
    Reputation: kiwi_matt's Avatar
    I have Rydes on my bike and they work fine. plenty while using a 6" rotor up front.
    In regards to your brakes, having no play have you tried resetting the pistons? Rear brake, if it doesnt feel spongy, may have contaminated pads. In which case you should clean the rotor with isopropyl alcohol and then fit a new set of pads.
    Depending on your riding style, the rear brake may not have bedded in properly yet either.
    mmmaxxis
    In my opinion, i would bleed them again because sometimes the manufacturer messes up on the bleeding or they just did a bad job. (also, air could have gotten into the tube if you bled them your self)
    Reputation: Qyota's Avatar
    I have the Hayes Ryde on my '09 Trek 8000. They make a ton of noise (mostly the rear), everything from squealing to grinding to spoke "twang". It's disturbing. The rear also drags a lot, no matter how I adjust the mount bolts.
    Anyone have any advice for fixing 'em? They are nearly new, and I've cleaned/sanded/re-bedded them several times now. They might be OK for an hour or two, then they start making awful noises again. Doesn't seem like the piston is retracting fully either...
    I have Rydes that squeal and I have found that the spray on anti squeal stuff you by at an auto parts store works for a while. Its a clear blue spray that stays tacky. You spray it on the back of your pads. For me it stops the squeal for several rides, but then you need to reapply it.
    Your brakes shouldn't be dragging. If you have a stuck piston you need to clean and or rebuild, which I haven't done so I can't give any advice on that.
  1. Hayes El Camino vs. Stroker Ryde....
    By Brad Trent in forum Brake Time
    Last Post: 02-03-2011, 11:40 PM
  2. Hayes Stroker Ryde help needed......
    By norbyd in forum Brake Time
    Last Post: 11-16-2009, 09:40 AM
  3. Bleeding my Hayes Stroker Ryde
    By hojgaard in forum Brake Time
    Last Post: 07-10-2009, 09:58 PM
  4. Hayes Stroker Ryde Question
    By MTBikerJoe in forum Brake Time
    Last Post: 06-27-2008, 01:37 PM
  5. Hayes Stroker Ryde vs Formula Oro K18
    By Ryan G. in forum Brake Time
    Last Post: 05-20-2008, 06:41 PM
