    New question here. Hayes Pad Metal Clips-Can You Buy Them??
    i bought a set of replacement pads for my hayes hydros (aztec brand) that surprisingly didn't come with the clips to hold the pads in. i used the old clips but they look pretty worn. can i buy the clips seperately from hayes--do bike shops sell them, if so which ones?? my local bike shop says i have to buy complete pads to get the little clips, not sure if they are right. thanks in advance.
    rolling in the greens
    Reputation: vermont's Avatar
    i hear about this
    a buddy of mine dropped his and spent a half hour looking for it...i buy the hayes pads they come with new clips right on the pads only $15 a much were the aztecs?
    the aztecs were supposed to have them on given the picture but the ones i bought for some reason didn't. just buy the hayes....i also found out you can get just the clips (called hayes) for about $3.50 per.....
    Reputation: skywaybuzz's Avatar
    Just use the old Hayes clips cause the ones that come with aftermarket pads like EBC for example were'nt the same shape as the hayes ones, so I used the old Hayes springs just cause they worked before. I'm not saying the EBC clips won't work well, after all there just clips, but you never know. If your old Hayes clips are worn suppossedly you can squeeze em back together a little where they hold the piston. You may also not like the Aztec pads and eventually go back to Hayes Sintered metal pads
  1. Hayes Brake Pad Replacements
    By J_B in forum Brake Time
    Last Post: 07-07-2004, 06:04 PM
  2. your hayes disc pad choice
    By danK in forum Brake Time
    Last Post: 07-05-2004, 05:40 PM
  3. Hayes pad wear on angle front/rear
    By NRSAirDriver in forum Brake Time
    Last Post: 04-08-2004, 09:00 PM
  4. Better brake pad for Hayes???
    By Disaster in forum Brake Time
    Last Post: 03-21-2004, 07:56 AM
  5. fork oil all over hayes pad
    By TMon in forum Brake Time
    Last Post: 02-23-2004, 08:10 PM
