Results 1 to 2 of 2
    Big M, Little organ.
    Hayes overextension?
    While I had my pads off my HFX-Mags, one of my not-so-smart friends squeezed the lever 50 times until the caliper pistons were all the way out. When I pushed the pistons back in to put some pads in, the brakes will no longer compress and the lever just goes to the bar. I tried bleeding them twice with no luck. Whats more, when I take out the bleeder screw, brake fluid comes out, which isn't normal for them. There don't appear to be any leaks, but I don't want to replace my master cylinder cartride unless it is really bad. Any ideas?
    Reputation: Kelso Jack's Avatar
    Bummer, Unless you are good at understanding the workings of your disc brakes and are mechanically inclined. You should probably head to your LBS. Sounds like you blew out the diaphram and wil need to be replaced. Dang, I hate it when that happens .
    Jack
  1. hayes hmx 1 a good pick....?
    By swimmerdude1127 in forum Brake Time
    Last Post: 03-01-2004, 05:16 PM
  2. Hayes or Avid for the Fuel?
    By Spaz in forum Trek
    Last Post: 02-23-2004, 05:13 PM
  3. Shimano XT755 or Hayes HFX Mag ?
    By MegaVolt in forum Brake Time
    Last Post: 02-11-2004, 03:24 PM
  4. Hayes or Avid for an '01 Fuel 90? (x-post)
    By Spaz in forum Brake Time
    Last Post: 02-10-2004, 08:01 PM
  5. Replies: 8
    Last Post: 01-20-2004, 03:20 PM
