Results 1 to 3 of 3
    Dirt Huffer
    Reputation: AC/BC's Avatar
    Are Hayes Mag compression fitting/barb fitting compatible with Shimano fittings?
    I need to cut the hydro line on Hayes Mags. Only problem is i've called around to the LBS's and can only find Avid and Shimano compression bushings. Does anyone know if any of these will work in place of the OEM Hayes fitting? I need to replace the barb and the compression bushing.
    Pic of it is the very bottom left pic (hayes mag)
    http://www.hayesdiscbrake.com/pdf/Bl...EnglishWeb.pdf
    EDIT: looks like from the pics that Shimano/Avid's compression olive is conical on both ends. HFX has the flat end and barb attached to the end so that wont work. I need a Olive that is flat on one side and conical on the other. S***.
    CTB
    CTB is offline
    Reputation: CTB's Avatar
    Hi I have lots of these Hayes compression olives in stock for sale.
    Visit the TeamMBM shop here: http://www.teammbm.co.uk/shop/brake_accesories.html
    to make a purchase.
