Results 1 to 3 of 3
    Hayes Mag Compression bushing removal?
    So I am trimming the hose on a Mag and i can't seem to get the compression bushing out of the hose nut anyone have any suggestions? It seems the bushing should come out of the end of the hose nut that is threaded but it seems stuck. should i just whack it through?
    solved it...from the factory the compression bushing was overtightened and expanded past the hose nut. A little encouragement from a pair of pliers and a screw driver dropped it out the threaded side.
    Can the compression bushing be re-used or are they trash once used? I have to cut down a couple of hoses and would like to know if I have to buy new parts.
