Results 1 to 3 of 3
    Kill that $hit!
    Reputation: MorphineAddict's Avatar
    New question here. Hayes Lever Question
    So I recently bought a bike off this guy and the only thing that was questionable was the rear break lever. This model has a "break-away" feature incase you eat it, the levers pop open and forward. The rear level is so sensitive, that it will pop out just from going off a curb. The guy that I bought the bike from said that all that needs to be done to it is to put some sort of washer in there. Is there anyone who knows what this guy is talking about, cause I sure dont. Thanks.
    rr
    rr is offline
    I don't do PC
    Reputation: rr's Avatar
    Quote Originally Posted by MorphineAddict
    It's the lever pivot assembly, it consists of 2 small plastic round thingies and a small rod that is pressed into the lever. Buy one at your shop($10)and ask them to install it, its a pain to install without this special tool. The levers are made to bend or break so the master cylinder is not damaged.
    Kill that $hit!
    Hayes Lever Problem
    Quote Originally Posted by rroeder
    Cool, thanks alot. I'm goin after work. Cheers!
  1. Hayes Mag lever reach adjustement loose?
    By ptolar in forum Brake Time
    Last Post: 03-12-2004, 07:58 AM
  2. Hayes 9, 6" to 8" swap with Q.R. question
    By Beau in forum Downhill - Freeride
    Last Post: 02-27-2004, 11:47 AM
  3. What size are Hayes brake bolts? Ti Question
    By FLYBYU in forum Weight Weenies
    Last Post: 02-24-2004, 10:01 PM
  4. Tech question re: Hayes brake levers.
    By Finch Platte in forum General Discussion
    Last Post: 02-03-2004, 09:27 PM
  5. Replies: 4
    Last Post: 01-22-2004, 12:09 PM
