Results 1 to 5 of 5
Thread: hayes hfx 9
    Mar 2006
    hayes hfx 9
    Hi to all, I just want to know if this is normal because I can see little bit of fluid on the bleeder cap on the lever and the rod with c-ring washer going to the master cylinder is a bit wet. I just received my brakes for rebleeding and installed it recently but it works fine. The lever play is ok and the brakes stops as i wanted. Thanks in advance.
    Expert Crasher
    Reputation: GreenLightGo's Avatar
    I don't have any fluid around mine.
    Try drying it off real well and see if the fluid returns.
    Happiness depends more on the inward disposition of mind than on outward circumstances. Benjamin Franklin
    Former Bike Wrench
    Sometimes after hydraulic disc brakes are serviced, there may be some residual fluid left over. Give them a good cleaning (rubbing alcohol works great here for cleaning DOT 4 fluid). Chances are you won't see any more fluid.
    Jul 2003
    Yup not uncommon to have...
    a little residual fluid in the areas you describe after a bleed. Clean it up and keep an eye on it for a couple of rides. If the fluid returns then you may have a problem. If not you'll be fine.
    Good Dirt
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    DOT 4-5 is water soluble wash it off & keep an eye on it.
    Formotion Products
    http://www.formot
