Results 1 to 3 of 3
    Hayes disc upgrade/ adapters?
    I want to equip my (2000) TREK 8000LT with the new Hayes Carbon Stroker ,front and rear. What adapters do I need? I have Judy Race Rock Shox (2000). I was also wondering what rotor size I should get. Any light you can shed on this would be appreciated.
    Reputation: vk45de's Avatar
    What size rotors you get will determine what adaptors you need. Since its a 2000, you need to check if the frame has 51mm IS or 22mm hayes direct mounts. The Judy has 51mm IS mounts so you would need http://www.chainreactioncycles.com/M...?ModelID=23538 if you want to run a 6" rotor. Note a 5" rear adaptor will become 6" front, 6"rear will become 7" front and so on due to the front IS mount being 20mm further from hub than rear.
    Reputation: bridgestone14's Avatar
    Mar 2005
    If the rear is a 22mm mount and you don't want to run a set of old school hayes discs then you will need on the adapters from http://www.torontocycles.com/ . If you use the B&S adapter at the bottom of the page I think you can use a 160mm rotor on the back by using a 160mm front adapter and mounting it to the back. I haven't done this myself but that is what I would try in your position.
    Looking for a Medium Scott Scale frame, preferably a 2012 in 26.
