Results 1 to 6 of 6
    Hayes calipers/ Xtr hubs
    Will a hayes disc brake work with an XTR hubset and rotor .
    Yes...
    Yes it will, is it advicable that I don't know, but it will work. I have the almost same setup, but with HFX Comps with XT hubs and rotors. You should probably get the adapter by problem solvers or DT swiss.
    Anything worth doing is worth overdoing...
    -Ricko, mtbr member
    Chrome Toaster
    Reputation: Hecubus's Avatar
    Same standard sizing, a few people have run that combo succesfully. You can also get that spiffy new DT swiss adapter and keep the hayes rotor.
    I have hayes HFX Mag brakes, with XTR-M965Hubs, RT-96 Center lock rotors and they work fine
    Thanks, I thought it would work buts its good to know someone else can confirm it. There seems to be a lot of good deals around on xtr hubs these days which is the only reason I would consider this idea
    qwf
    qwf is offline
    Sep 2004
    Same issue here: I have hayes HFX 9 brakes, and I just installed with XTR hubs and Center lock rotors and rotors seems to be fine.
    I heard that this may cause bad brake pads consumption resulting in vibrations and need for an early substitution of brake pads.
    Any hint on that?
  1. New XTR with Hayes Calipers?
    By Erik in forum Brake Time
    Last Post: 12-02-2004, 06:57 PM
  2. Best pads for XTR disk calipers?
    By fallzboater in forum Brake Time
    Last Post: 11-30-2004, 05:38 PM
  3. XTR or XT disc hubs???
    By staind in forum Wheels and Tires
    Last Post: 11-29-2004, 06:11 PM
  4. Avid Mechanical Calipers with XTR 965 Splined Hubs?....
    By BigfootDenny in forum Brake Time
    Last Post: 06-26-2004, 10:31 PM
  5. Lightweight steel rotors for XTR calipers?
    By Knut in forum Weight Weenies
    Last Post: 04-29-2004, 12:14 AM
