Results 1 to 3 of 3
    Reputation: Uruk-hai's Avatar
    Hayes Brakes - Shimano Rotors?
    I recently switched out my Shimano mechanical disc brakes for a set of Hayes on my Kona hardtail. I kept the Shimano 6" rotors because I took the Hayes off of an 8" rotor setup on my other bike.
    My question is this: The Shimano rotors are stamped "Resin Pads Only" but my Hayes pads are sintered metallic. Is this going to be a problem? The brakes do sound raspy although the braking power is there. I haven't taken it out on a real ride yet as I am not sure about the rotor/pad compatibility. Any thoughts?
    Mar 2005
    Quote Originally Posted by Uruk-hai
    I believe that you would wear the rotor down faster, and possibly make it hotter than average.
    Resin pads are a little softer, and possibly the Shimano rotors you use are slightly softer than a rotor designed for sintered.
    If you had hydraulic brakes the potential extra heat would be a major problem.
    Now since you have mechanical, I guess you'll just have to buy a rotor prematurely.
    Quote Originally Posted by Poetic_Dancer
    Thanks P.D.
    I guess I should have said Hayes hydraulic as that is what I installed. I will keep an eye on it and see what happens. Thanks for the reply.
  1. What are the BEST brakes on EARTH?!
    By norwoosg in forum Brake Time
    Last Post: 02-24-2005, 10:38 PM
  2. xt centerlock hubs, hayes mag brakes: what rotors?
    By Turtle-Dog in forum Brake Time
    Last Post: 12-01-2004, 03:04 PM
  3. Use hayes rotor with Shimano XT brakes?
    By Tourendo in forum Brake Time
    Last Post: 11-20-2004, 02:09 PM
  4. Hayes rotors for Shimano calipers?
    By ryan123 in forum Brake Time
    Last Post: 08-06-2004, 02:08 AM
  5. 4 bolt rotors for Hayes 6" brakes
    By Telemahn in forum Brake Time
    Last Post: 06-09-2004, 06:00 PM
