    Hayes Brake No Front HELP?
    Ok guys I have a older set 2005 Hayes hydraulic brakes and the front lever will now go all the way to the grip will little to no brake power. What to I do?
    Check for possible leaks, then bleed it.
    Quote Originally Posted by csmitharchitect View Post
    I do not see any leaks can someone talk me thoughtthe bleeding process?
    If you go to the Hayes website you can determine which model brakes you have, and download the bleed instructions.
  1. Hayes Front Brake issues...
    By norbyd in forum Brake Time
    Last Post: 09-02-2010, 08:22 PM
  2. Hayes Stroker Trail Front Brake help
    By NOVAdub in forum Brake Time
    Last Post: 06-06-2010, 11:06 AM
  3. Problem with Hayes Nine front brake
    By singletrack pops in forum Brake Time
    Last Post: 01-30-2010, 05:25 PM
  4. Hayes Stroker front brake problems!
    By tbone330i in forum Brake Time
    Last Post: 05-27-2009, 01:02 AM
  5. Hayes 9 Hydro Front Brake Squeaking
    By flat tire in forum Brake Time
    Last Post: 06-06-2006, 10:30 AM
