Results 1 to 3 of 3
    Hayes bleed fitting
    I have some older Hayes Mag brakes that needs to have one of the master cylinders rebuilt, and as a result will need to be bled.
    I don't have the bleed fitting and can't find it anywhere other than expensive 'bleed kits' but I can find the fittings by themselves for a couple bucks for other brakes. Can anyone help direct me to find the older style Mag clear plastic lever bleed fitting for cheap?
    I tried Hayes c/s and they were awesome in sending me the parts needed to repair my lever for free, but they neglected to include the bleed fitting I was mainly asking for, so far it has been 5 days since I sent a follow-up upon receiving the initial parts (washer and c-clip) but no response and I'm getting antsy to repair my Bullit and ride it again
    you can see the clear plastic adapter in this picture -
    2013 Trek/Gary Fisher Rumblefish Elite XXL/23"
    120mm 29er
    2004 Santa Cruz Bullitt XL White
    170mm 26er
    Pull the plunger from this syringe and angle upwards while you push fluid into the caliper bleed w/ another syringe. The pictured syringe seals perfectly on the Mag lever.
    2 of Monoject Type Curved Tip 12cc Utility Irrigation or Feeding Syringe 12ml | eBay
    Thanks a bunch!
    120mm 29er
    170mm 26er
  1. Anybody need a Hayes bleed kit?
    By bad_andy in forum Colorado - Front Range
    Last Post: 04-05-2013, 12:13 PM
  2. Need threaded bleed hose fitting for Avid Elixir
    By joe_bloe in forum Brake Time
    Last Post: 02-20-2012, 09:09 AM
  3. Reverb Xloc brass bleed fitting source?
    By damagr in forum All Mountain
    Last Post: 10-24-2011, 12:49 PM
  4. Help with Hayes HFX 9 rebuild and bleed
    By GVSS in forum Brake Time
    Last Post: 08-03-2011, 06:36 PM
  5. Replies: 0
    Last Post: 05-31-2011, 08:28 AM
