Results 1 to 2 of 2
    Hayes Barrel Nut - hayes mag
    I have a pair of hayes mag levers and it deals with the barrel nuts. I wanted to get a pair of straitline barrel nuts to replace the standard hayes and its harder to get. Is there any barrel nuts that can be substituted and what is the size?
    Does your lever need a 2mm hex, 2.5mm hex, or flat blade screw driver to adjust the reach? The 2.5mm is the same thread on the Stroker Ryde kit so you can use that one, the 2mm uses the same bushing as the Nine and Sole brakes, and if you need a flat head screw driver you're out of luck as those are long gone.
    You are not what you own.
