Results 1 to 2 of 2
    Scuffed
    Reputation: Amber's Avatar
    Hayes 9 rotor clearances
    I have a Hayes 9 6" brake on the rear of my Reign. Have done 3600kms on it and never had a problem until now. They have never been fiddled with since I purchased the bike and the pads still look ok. They are now continuosly rubbing on the rotor and no matter how much I align the caliper they continue to rub and there is hardly any clearance between the pads and rotor. I took the caliper off and used the Hayes spacer to push the pads right out again but they return to the same spacing once the brake is operated. What am I missing? It's hard yacker climbing the tank as it is without the psychological brake rubbing noise.
    NO REIGN NO GAIN
    ......MMmmmm
    Meh.
    Reputation: XSL_WiLL's Avatar
    Your system is probably overfilled. Open up the bleed port at the lever, and then push the pistons back in, this will force any excess fluid out.
