Results 1 to 5 of 5
    Hayes 180mm rear?
    Is there an Avid adapter that would allow me to run a 180mm rear disc with a hayes mag caliper?
    Slow and steady
    Quote Originally Posted by al-r
    Yes. Just buy the Avid 180/185mm rear disc mount and an Avid 180/185mm disc.
    Note that you can also use a Hayes Psylo 8" front-mount bracket to mount a 7" (180/185) rotor on the back. If you already have an 8" on the front, it is a quick thing to do a test mount .
    I am running a Hayes G2 caliper with an Avid 185mm rear mount and a Hope mini 185mm rotor. Works great.
    It's a 6" 29er, 69 HTA, 29" standover, setup for 31.6 Joplin, 83mm BB, blah blah blah. A bike for being stupid. --Walt Wehner
    Do It Yourself
    Reputation: Homebrew's Avatar
    The Hayes 203 front IS adapter would probably work as well.
    Long Live Long Rides
    Apr 2005
    Quote Originally Posted by Tony
    Tony I am looking to fit a 7 inch rotor using my Hayes HFX9 caliper, but the LBS says the avid adapter wont work (based on their experience). You mention a "hayes Psylo 8" front mount " adapter will work on the rear, are there different adapters for different forks to watch out for. Do you know if the Hayes G2 caliper different fitting from a HFX9?
    Slow and steady
    Hayes G2 caliper is what the HFX9 uses. The Psylo 8" mount is also known as the international-standard 8" mount. Note that the 20mm fork brackets are too thick.
    I am using an Avid 185mm rear international-standard bracket right now and have been for over a year on my Titus. Note that on my bike the bracket is a little too narrow, so I had to use a couple of shims to space the bracket out a bit, 1 or 2 mm. That is probably what has stymied your LBS in the past.
    -Tony
  1. Hayes lever pull different front vs. rear
    By spacoli in forum Brake Time
    Last Post: 03-17-2005, 04:41 PM
  2. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  3. Iso adapter for Hayes G1 rear caliper?
    By Tourendo in forum Brake Time
    Last Post: 11-30-2004, 08:58 PM
  4. Blur with squeaky Hayes rear brake
    By Jesterrider in forum Santa Cruz
    Last Post: 07-13-2004, 11:41 PM
  5. Replies: 2
    Last Post: 06-08-2004, 04:55 PM
