Results 1 to 3 of 3
    Hard lever after hose shortening Shimano XT
    Hello, just shortened my new xt rear brake everything seemed to go well but the lever is extremely hard and the pistons wont go back all the way. It takes a lot of pressure to press in the pistons as far as i have with a plastic tire lever, do I just have too much brake fluid for the new hose length? Thanks a bunch! would appreciate any feedback.
    Take the wheel out and remove the brake pads. using a q-tip, swab some mineral oil on the sides of the pistons. Grab a rag and open the bleed screw 1/4 turn (with the rag over the opening), and push the pistons back into the caliper body (gently).
    I imagine that should take care of your problem. If not, you should start investigating other things.
    Quote Originally Posted by wschruba View Post
    Yes you are correct, just opened the bleed screw and then pushed the piston backs with ease. everything feels like the XT goodness that it should be. Appreciate the response!!!
  1. Shortening Shimano XT hoses
    By jmallory in forum Brake Time
    Last Post: 08-10-2014, 01:23 PM
  2. Replies: 7
    Last Post: 03-20-2013, 06:47 AM
  3. Command Post Blacklite Lever Hard to Push!
    By MXFanatic in forum Specialized
    Last Post: 12-24-2012, 04:17 PM
  4. school me! shimano break house and parts ???
    By winginit in forum Brake Time
    Last Post: 09-09-2012, 05:56 PM
  5. Hayes nine: lever is really hard
    By machine4321 in forum Brake Time
    Last Post: 10-21-2011, 06:12 AM
