Results 1 to 14 of 14
    Hanging bike upside down w/ hydraulic brakes?
    Is it ok to store a bike w/ hydraulic brakes upside down? It seems like I read a post one time where sombody prefered mechanical brakes so they could store their bike hanging upside down. FWIW my brakes are Shimano XT M775 and they work perfect. Thanks in advance for your advice.
    Brazos
    locked - time out
    I went back in time and checked with someone in 2002 and they said it's not a problem.
    Never trust a fart
    Reputation: frdfandc's Avatar
    You should be ok to hang your bike upside down. Hydraulic brakes are designed to be sealed systems. Occasionally you will get one that might get some air in the system from hanging it upside down, but this isn't the norm.
    Reputation: Fix the Spade's Avatar
    Your brakes will be fine.
    BUT.
    What is your fork? Rockshox forks in particular do not like being hung upside down for any length of time. But with any suspension fork it's not generally advisable to leave it upside down for storage.
    Thanks Fix the Spade. I did not even think about the Reba fork. I was about to go hank my bike up. I knew the brakes were sealed and in theory should be ok (though a lot of my theories turn out bad which is why I asked). I guess I will figure out a new plan.
    Reputation: wormvine's Avatar
    Quote Originally Posted by Brazos
    Air will not get into the brake system no matter which way you hang it.
    But trapped air in the system can migrate to the lever and cause issues. There shouldn't be air in the system but it is not always an apparent issue until it reaches the lever.
    I have been hanging my wife's bike with a RS Pike 454 from a hook now for 3 years with no ill effects whatsoever. And I hang my other bikes the same way. It has also been hypothesized that hanging forks upside down allows oil to saturate the seals which in turn helps keep the fork seals lubricated.
    Old man on a bike
    Fox actually recommends "As a general practice, the bicycle (or the fork) should be stored upside-down, to maintain lubrication of the dust wipers and foam rings".
    suum quique
    I hung my bike upside down for a long time. The brakes are find but the RockShox Dart2 was oily on the top
    locked - time out
    Quote Originally Posted by Fix the Spade
    BUT.
    Fox recommends this practice.
    Reputation: riperush's Avatar
    i was wondering about something like this too. I was thinking maybe hanging my bike by the front tire via "J" hook. I have a Rock Shox Tora front fork, so I'm assuming this probably wouldn't be a good idea? Maybe hang from the rear tire?
    Hang it by the front wheel, hang it by the back wheel, hang
    it upside down, or rightside up. I reall don't think it matters. A
    lot worse happens when you ride the you know what out of it.
    Best, John
    Singletracker
    Jun 2005
    Quote Originally Posted by wormvine
    If hanging a bike upside down migrated trapped air through the system it would go to the calipers not the levers.
    Reputation: LarryFahn's Avatar
    When you take the bike down, cycle the fork several times before actually riding it.
    "If hanging a bike upside down migrated trapped air through the system it would go to the calipers not the levers."
    Word! Ttyl, Fahn
    Hubbard Bike Club
    Quote Originally Posted by blue_neon
    Yep I misread the the OP. I hang my bikes from one hook not 2.
Members who have read this thread: 11
