Results 1 to 5 of 5
    Grimeca Disc Brake Fluid
    I believe Grimeca System 8 Brakes use DOT brake fluid. These are virtually the same disc system as the SHIMANO XT Discs ( older, non splined system). I was wondering if they can be bled and use Shimano Mineral Oil without any problems or are there downsides that I have to worry about?
    meh....
    Reputation: Monte's Avatar
    Quote Originally Posted by jisozaki
    All the seals are different, made for DOT fluid. Not sure you'd want to switch.
    Quote Originally Posted by Monte
    My non-mechanical mind understands not switching from Mineral Oil to corrosive Brake Fluid but it would seem that going from Brake Fluid to non-corrosive Mineral oil might be okay. Am I wrong?
    Uber V Cripp
    Reputation: jdcamb's Avatar
    As explained to me by the SRAM guy..... The weight of DOT fluid is heavier then mineral oil and will change the lever feel in a way that wouldn't be good (what that means I don't know as I have never experimented). Plus you will never be able to put DOT fluid back in to "fix" them as some mineral oil will still be in the system and inversely DOT fluid will still be in the system before you change the fluid type. I was also told that you shouldn't mix fluids (why I don't know)?? You will also ruin the seals. Basically it sounds as if you will ruin your brakes if you do that or atleast get subpar performance. Better to leave well enough alone IMO......jdcamb
    Authority is dead!
    Reputation: Lucky13's Avatar
    dot
    DOT 3/4 for Grimeca only.
    For the love of Oi
    Rent a house at Attitash
  1. Deore disc brake with CODA discs?
    By nusbus in forum General Discussion
    Last Post: 07-09-2004, 06:42 AM
  2. deore discs?
    By xisaacx in forum Brake Time
    Last Post: 07-06-2004, 03:44 PM
  3. Replies: 2
    Last Post: 07-01-2004, 03:12 PM
  4. Surly 1x1 and Avid mechanical disc brake issues...
    By pennstatebiker in forum Singlespeed
    Last Post: 05-16-2004, 04:54 PM
  5. Avid road disc brake for mtb
    By K2footsrgn in forum Brake Time
    Last Post: 02-17-2004, 01:54 PM
