Results 1 to 11 of 11
    Grimeca Brake Pads
    I Have Recently Purchased A Saracen Vapour Pro (year Unknown )
    It Has A Grimeca Mechanical Front Disc Brake And The Pads Are Round And 22mm In Diameter Approx 6mm Thick With A 12mm Mounting Tab With A Single Screw Hole In It,the Rear Of The Pad Has A 3mm (approx ) Indentation , The Caliper Is Bright Yellow With The Numbers 10 And 18 On It , I Need A Pair Of Pads Which Appear To Be As Common As Hens Teeth , Any Ideas Welcome . Help !!!!!
    Pictures.
    i will add some pictures on monday thanks
    Try to post pics of the pads on there right now so we could try to match them up.
    cant get photos on the post because the maximum file sizes are tiny and my camera res wont come down that low , if you could e-mail me at westlandkirbys@aol.com i can send photos back to you
    google microsoft powertoys image resizer. Install it, right click on the pictures and select resize. Select medium and then use that to load to the forum.
    photos attached
    Quote Originally Posted by kirby30
    What's with the 16 year old MySpace capitalizing of every word?
    Thanks for your comments the-one1 , very useful . I hope you find something more constructive to do with your time !!
    Thanks, I Try My Best.
    From the looks of the pads, it looks like pads on a *-Mart bike I used to have. They were Promax pads. Round and with a tab.
    thanks
