Results 1 to 10 of 10
Thread: Grease.
    Pwnerer
    Reputation: Boris4ka's Avatar
    Grease.
    Does it matter what type of grease I use for my cable housing? I have some that's meant for high performance RC car differentials. Can I use it?
    My signature is better than yours.
    I am a pathetic rider...
    That is mostly silicon grease, and I would stay away from it. In my experience my gables ran better without grease, just a light oiling like some tri-flow or what not.
    Save the Earth, Ride a Cyclist
    Reputation: shiggy's Avatar
    Dec 1998
    I never use lube on my cables. Full housing and Teflon coated cables work best dry.
    mtbtires.com
    Pwnerer
    Quote Originally Posted by shiggy
    Hmm, but wouldn't grease reduce friction?
    Quote Originally Posted by Boris4ka
    At first, yes, but after some time, it will attract dirt and that would ruin everthing.
    Pwnerer
    Quote Originally Posted by angelobryant
    I can see that happening with partial housing, but I'm using full housing.
    Dec 1998
    It still gums up with use.
    I replace cables maybe every other year. Have not lubed a cable in more than ten.
    mtbtires.com
    As Shiggy advises, use a good quality cable and housing dry. No grease.
    Pwnerer
    Ok thanks everyone.
    Reputation: itsdoable's Avatar
    A time when grease in the cables is useful is riding in below freezing weather, and storing your bike inside (above freezing). Melt water (or from a previous rainy ride) does get into your cable housing. It'll freeze in there during a sub-zero ride, and you either cannot shift, or cannot brake. BTDT, several of us.
    Properly greased cables prevent water intrusion, and even if some water gets in, it will prevent it from freezing your cables solid.
