Results 1 to 2 of 2
    Goodridge + Formula Oro K24
    Can anyone tell me which goodridge hose kit will fit formula oro k24's
    This thread says the oro series use either 101 or 107 kit:
    http://forums.mtbr.com/brake-time/formula-one-goodridge-hose-480423.html#post5232035
    I reckon it's the 101 kit but need but want to be sure before buying.
    meow, meow.
    Reputation: J. Random Psycho's Avatar
    Yes, it's kit #101. However, it includes 2 banjo bolts, whereas you would only need one. The other is the long K24 caliper banjo bolt - you already have it. )
    By the way, consider going for aluminum Goodridge connector kit and a separate length of hose, as opposed to the full hose and connector kit. You can save some 16 grams like this. The full kit contains stainless steel connectors.
