    Oct 2007
    New question here. Going IS to Post mount
    Hi, im looking at new forks which have are post mount. I currently have an IS front fork-with adaptor and caliper. The brakes are shimano non-series mechanical-so do i need an adaptor to mount my IS brakes onto a PM fork? How much will a shimano adaptor cost? Any help appreciated, Chris
    What size is the rotor? If 6", you should be able to just remove the caliper from the adapter, and bolt it to the post mount.
    Oct 2007
    Cheers, it is a 6" rotor so shouldn't have too many problems. Thanks, Chris.
    Oct 2007
    Is there a adapter that will allow me to fix my IS brake caliper to a post mount fork.
    Hope mono mini with 6 inch rotor IS mount to a new FOX PM.. with out up size the rotor
