Results 1 to 5 of 5
    Reputation: eurospek's Avatar
    Getting rid of front brake buzz
    Bike in question is a Kona Stinky with 8" Hayes discs front and rear. Whenever you take a rather hard and sharp turn, the front brakes emit a buzzing noise, almost a vibration sound. I've made sure everything is tight, rotors on the hub, and the caliper on the adapter and the fork and it's quite annoying.
    I have no idea where else to look for a fix, and my other bike with 8" rotors is silent when turning.
    konahonzo
    Sounds like fork flex. I get the same in the back turning at high speed.
    Reputation: RustyIron's Avatar
    flex
    Oh, and larger rotors magnify the effect of flex. Just think of it as corner traction comtrol
    Binned
    Nov 2008
    My Marta Storm SL 180mm rotor does that in the front. There is play in my Fox fork as though a bushing is failing and that is what we think is causing or at least amplifying the buzz sound/sensation....
