Authority is dead!
General bleeding ?n
Do I have to completely fill the reservoir on my lever? Is that ok to have some air between the oil level and the cover? Say if the reservoir is 3/4 full and there's no air in the lines.
simply me
Fluid is drawn from the reservoir into the system as the pads wear, if the reservoir is not full you run the risk of drawing air into the system as the pads wear. Also if the lever is actuated while the bike is upside down you will suck air into the system.
By sp0om in forum Beginner's Corner
Last Post: 03-02-2004, 05:04 PM
By AnoBlur in forum Brake Time
Last Post: 02-29-2004, 07:31 PM
By bagz007 in forum Shocks and Suspension
Last Post: 02-26-2004, 04:54 PM
By Lucky13 in forum Brake Time
Last Post: 02-11-2004, 08:37 PM
By vuduvgn in forum Singlespeed
Last Post: 01-14-2004, 12:25 PM
- You may not post replies
- You may not edit your posts
Forum Rules
