Results 1 to 5 of 5
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Front Rotor not aligned?
    When I lightly tap the rear rotor, I hear this nice metallic ring, kinda like a tuning fork. When I do this to the front rotor, I hear a dull thwack . . . little to no resonance. I assume this to mean something is outta alignment. Where would I start?
    These are brand new Avid Elixir 5's on a 2011 Fox Float.
    Reputation: yetibetty's Avatar
    If the front rotor is bigger than the rear then it will sound different. If you can spin the wheel without the pads rubbing then you are OK
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by OO7
    If the brakes work, do nothing.
    mtbtires.com
    007 is offline
    b a n n e d
    Jun 2005
    They certainly work, however there's definitely pad rub, and uneven at that. Its not constant around the entire rotor, but its clearly not properly aligned.
    Never trust a fart
    Reputation: frdfandc's Avatar
    The rotors are thin enough to be tweaked so they don't rub. You can use an adjustable wrench and LIGHTLY apply pressure away from where its rubbing. I prefer to use this tool.
    http://parktool.com/products/detail....t=14&item=DT-2
