    Nov 2006
    front post mount 180mm shimano adapter for rear?
    I am putting shimano xtr rear brakes and 180mm rotor on my Anthem X 29. My adapter I have is not right as it is for IS. Is it correct to use the same front post mount adapter on the rear with my set up? I asked my shop and they said that they did not see a specific rear adapter for this set up and were not sure.
    Thanks for any input.
    Binned
    Nov 2008
    Quote Originally Posted by DanielM3
    Usually, an adapter that works for a 180 front, works for a 160 rear.. a 160 front works for a 140 rear...and so on...
    Reputation: shiggy's Avatar
    Dec 1998
    Post mount spec is the same front and rear (axle to caliper mount). A 180mm rotor post mount bracket is the same for front or rear.
    mtbtires.com
    Binned
    Nov 2008
    Quote Originally Posted by shiggy
    Sorry, I was referring to PM to IS adapters...
