Results 1 to 16 of 16
    Front pads catching but only when i turn my handlebars
    Hi peeps I have had this problem for 2 years and it is driving me insane I had quite old rockshox boxer forks and my mate told me to get later ones as stancions are thicker so you get less flex , ok so I did but problem is still there and now I hardly turn the handlebars at all and I can here them catching, the pads are siting with equal distance either side to the disc and don't rub when tested only when I ride the bike has anybody had this problem or know what it is or what I can do any help would be great its driving me insane
    Surely someone has some advice on this
    Jun 2012
    So you get light pad rub when you are cornering? Nothing when going straight?
    Yeah it only does it when i corner ive been told rockshox boxxer forks all do this not so sure
    Jun 2012
    Sounds like flex in the fork, nothing you can really do about it.
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    A stronger connection between the hub and fork helps. The solution could be as simple as tightening the QR. Thru-axle conversion (if your hub allows) is also one way to make it stiffer.
    Rockshox boxxers have 20mm thru alxe which is as tight as it can be so not that was thinkin about fiting floating discs
    Jun 2012
    That is as stiff as it will get, not sure what to tell you.
    Be instresting to see if anybody else has had this problem with boxxer forks
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    How are your hub bearings? No slop there?
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    Drinkin' the 29er KoolAid
    Reputation: kwarwick's Avatar
    Problem could be play in the hub. Try grabbing the front wheel at the top and see if you can move it side-to-side at all. If you feel any kind knock or if the rim moves significantly then perhaps the bearings in the hub are worn. Many modern 20mm thru axle hubs use something like a 6804 cartridge bearing... cheap and easy to replace when they get worn out.
    They are fine no play at all not long had them replaced
    Floating rotors won't help with this issue either. The rivets on a floating rotor allow for a small amount of slippage as the diameter of the rotor track changes due to thermal expansion. Side to side the rotor is still held relatively firm.
    Arr ok thanks for that well is it normal for these type of forks ti have this amount of flex
    With a 20mm thru-axle that's installed tight enough I'd be really surprised if you could flex a fork enough to get rotor rub. Any time I've seen that happen it has been a problem with either the hub bearings or the QR/thru axle interface.
    Mechanical disc? Housing too short?
  1. Rotor rubs on pads when turning
    By Brave Little Toaster in forum Brake Time
    Last Post: 05-10-2013, 04:04 PM
  2. front wheel, fork, disc brake
    By massimopotenza in forum Beginner's Corner
    Last Post: 09-16-2012, 11:25 AM
  3. ??disc front wheel for rim brakes
    By radnur22 in forum General Discussion
    Last Post: 08-06-2011, 09:49 PM
  4. How to remove front wheel with disc brakes?
    By Kamil in forum Beginner's Corner
    Last Post: 04-23-2011, 07:09 PM
  5. Lacing a 29er Disc Front Wheel
    By barretxcr in forum Wheels and Tires
    Last Post: 04-12-2011, 02:26 PM
