Results 1 to 7 of 7
Thread: Front Disc only
    Reputation: GinoLicious's Avatar
    Apr 2005
    Front Disc only
    Okay yeah, im going to be purchasing my first Norco soon, and yes it only has one front Disc brake.. Read is a V-Brake. Im just curious on how bad this is? Like is it going to offset the bike a lot? Yes i know that 70% of braking power is in the front, but im just curious, will this brakes perform well together to modulate and all that stuff for control,etc. Or would droppin on that read disc be a smart idea at the start just so its balance and control is better from the rear?
    I railed it like Kong
    Reputation: Arkon's Avatar
    I have a HT with a disc up front- V in the rear. I find myself really grabbing the rear and barely pulling the front. You get used to the difference and it won't bother you too much if this is your only bike. My main ride is hydrolic disc front/rear, so when i get on the HT it takes a little bit to get the feel back.
    If money is no option- spend it. You will feel more balanced.
    If it's a $$ issue- it works fine, upgrade when you find a smoking deal.
    I'm UNIQUE... just like everybody else.
    Apr 2005
    Thanks for your input.. Yeah i may wait to slap the rear disc on. Then again it depends how much the bike shop will slap on another disc for me. If it sounds alrite, then ill just go with it kinda thing.
    On MTBR hiatus :(
    It's not so bad a way to go. I rode a similar setup for about two years and liked it enough that I almost stuck with it on my next bike.
    The thing is, modulating the rear wheel is always touchy, V or disc. When braking hard, you're going to be working them independently no matter what combo you have.
    Running a mixed setup, I learned the importance of the front brake and how to lean heavily on it under most circumstances.
    It's not a bad way to go, and doesn't compromise much in most riding conditions.
    Apr 2005
    I guess i will just try it out for a bit and see where it goes.
    Reputation: brrrrp's Avatar
    Apr 2005
    I run a disc up front and v in the rear and never really had any huge problems. The set-up works for me just fine the extra braking poweer took a little getting used to but now its all good.
    Apr 2005
    so i guess it snot really a disadvantage to have this set up.
  1. 2004 SJ FSR Exp. Disc - shuddering front brakes
    By Richie in forum Specialized
    Last Post: 01-11-2005, 10:39 AM
  2. Who makes a solid axel BMX style front hub that's disc?
    By BudhaGoodha in forum Wheels and Tires
    Last Post: 12-24-2004, 07:16 PM
  3. 28spk front disc wheel thoughts
    By thebronze in forum Wheels and Tires
    Last Post: 11-15-2004, 10:52 AM
  4. front disc
    By sbek in forum Brake Time
    Last Post: 04-09-2004, 04:27 PM
  5. which front disc hub similar to XT nondisc?
    By jh_on_the_cape in forum Wheels and Tires
    Last Post: 02-04-2004, 03:52 PM
