    Baby Bear is in the house
    Reputation: r1Gel's Avatar
    New question here. frame brake stud cover?
    I'm not sure if this is a brakes question.
    I've removed the brake studs (where cantilevers mount) from my frame and want to cover them up for a cleaner look. Does anyone know the size/thread pitch of the bolt needed to replace the studs? Is there a manufacturer that actually makes these specifically for bikes?
    Thanks in advance for any help.
    Better to have and not need it, than to need it and not have it.
    Reputation: knl2stl's Avatar
    Jan 2011
    Size can depend on the frame make, most likely 8 or 10mm. Do a search on "brake boss plugs." Here is an example: Search results for boss plugs | Jenson USA Online Bike Shop
    Quote Originally Posted by knl2stl View Post
    Plugs! I was racking my brains trying to remember what it's called
    Thanks for that
    PS
    If I'm not mistaken, it's 8mm for fork bosses and 10mm for the frame.
    Man, what a diff just knowing what they're called. I did a Google search and found they're simply M8 or M10 by 1.25 thread pitch bolts. I'll try to see if my local hardware store has 'em.
    Thanks again.
