Results 1 to 5 of 5
    Reputation: misctwo's Avatar
    Fox 40 caliper mount info
    Does anyone have info on the new Fox 40 caliper mounts, or know where I can find it? also, if anyone knows about compatibility with hopes, avids, etc, that'd be great.
    i spoke with someone at go-ride that said mono m4(caliper 8) with a 205mm rotor will not work on the fox 40. apparently this is the modification: buy a new #3 caliper(designed for a 180mm rotor) and install/bleed it, then buy a 220mm rotor and mount it on the hub. 220. Oh my. Soooooo.....anyone want to buy a set of brand new Hope mono m4's for $300? pm me!
    M
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    Just get a 245mm rotor and run the #8 caliper.
    Funny, but the 40 we rode at IBike had a "tiny" rotor on it. It sounds like the 40 has IS tabs which basically mimic placing a 40mm adapter between the fork and the caliper. Maybe we had a standard 160mm Hayes caliper adapter mated with a 200mm rotor. Not sure, but that seems to be how the math pans out...
    My video techniques can be found in this thread.
    Quote Originally Posted by tscheezy
    great shot. maybe i'll just bolt on a couple AOL CD's!
    i actually just got an as-x frame. so, i had another look at the front hope mono m4 caliper and it's actually a #6. not sure, but looks as though it should fit the 40....please, tell me it will! i was told the #8 will defintely not work unless major mods are done, but please, please tell me a #6 caliper will make the cut!!!!
    Yup, you're set!*
    *Please note that I have absolutely no idea on this topic, but I hate to see a man in such pain.
    Yup, you're set!*
    argh.
    argh.
  1. Fox 36 or 40 on a yeti AS-X?
    By misctwo in forum Yeti
    Last Post: 01-27-2005, 02:03 PM
  2. 2005 Fox 40 pricing
    By mtbman4 in forum Downhill - Freeride
    Last Post: 12-08-2004, 06:44 PM
  3. Fox DHX 5.0 - Large Moment info
    By Bob the Wheelbuilder in forum Ellsworth
    Last Post: 08-06-2004, 08:30 PM
  4. Replies: 2
    Last Post: 06-08-2004, 04:55 PM
