Results 1 to 5 of 5
    formula two syringe bleed technique
    can someone post, or message, or email me the two syringe bleed technique for the formula b4sl? I got the bleed kit, but don't know where all the nuts go, thanks!
    simply me
    Reputation: bostonkiwi's Avatar
    Quote Originally Posted by bostonkiwi
    thanks
    thanks for posting that link. I think I got most of it sorted out, but I just want to check on a couple things.
    The fourth brass fitting goes into both the caliper through the bleed hole or into the master cylinder from the top also through the bleed hole. The third brass fitting goes into the master cylinder from the front. Is this correct so far?
    What are the 1st and 2nd brass fittings for? I didn't see anything that seems to refer to these two in the instruction.
    Thanks for all the help
    Quote Originally Posted by Biandon
    Correct. The other fittings are for older Formula brakes, you dont need them. :-)
    Call me if you have a problem 800 222 8356
    Thanks Thorsten
  1. Website with info on 04 Formula brake?
    By CraigH in forum Brake Time
    Last Post: 02-12-2004, 02:04 PM
  2. Replies: 4
    Last Post: 02-12-2004, 10:55 AM
  3. Replies: 3
    Last Post: 02-04-2004, 03:36 PM
  4. Hayes malfunction, bleed does not fix
    By Soloracer in forum Brake Time
    Last Post: 01-25-2004, 07:35 PM
  5. Avid Mechs on Formula hubs
    By spangelsaregreat in forum Brake Time
    Last Post: 01-23-2004, 10:51 AM
