Results 1 to 2 of 2
    Don't be a sheep
    Sep 2004
    Formula RX lever position help.
    Coming from Avids and Shimanos I'm a little bummed that the Formulas can't adjust closer to the bar, engagement is much further out than I like. Is it possible to bleed them down to lower the contact point?
    Note. I have run the adjustment screws all the way in to get the levers closer to the bars but it's still note close enough.
    "Do not touch the trim"
    Formula makes a kit so you can adjust pad contact "Feeling Control System".
