Results 1 to 6 of 6
    Oct 2013
    Formula rx advice needed...
    Anyone here have any experience with the Formula RX set up? I'm new to all this mountain bike stuff, and only owned the bike 4 weeks. Was out riding it last week at local bike park and my back brake lever started to gain more movement. By that I mean coming closer to the bars. It got to the point where I would have to touch the bar to lock up the wheel. There are no visual leaks within the hydraulic system, so I thought perhaps its the pads burnt out?! But no there's loads of life left in them. I've even looked to see if there is any adjustment at the lever but I can't seem to see anything.
    I'm open to any suggestions as to what I can do?!
    bike rider
    Reputation: Lelandjt's Avatar
    Bleed it.
    Keep the Country country.
    Oct 2013
    Could I still get air in the system even if there is no obvious sign of a leak?
    bike rider
    Maybe. The first step is always to bleed. If it feels great after a bleed but the same symptoms return later call Formula USA, describe the situation, they'll give you an RA# so you can send it in for warranty work. I had a reservoir bladder burst causing the same symptoms and they took care of it. The leak was hidden under where the lever mounts to the bar so it wasn't obvious.
    There's a 2mm allen reach adjustment screw where the piston is pushed by the lever but you say the stroke increased, not that the range moved in so I don't think it turned itself randomly. This used to happen to old Hayes brakes but I've never seen it with Formulas since they have pretty distinct detents.
    Reputation: cman8's Avatar
    bleed. It will solve all your problems. I have had Rxs on for over a year now and still feel solid after last bleed.
    Bleed them first and see how they feel. If they go bad again call formula. Most likely there is a leak somewhere. I've had mine on my Rocky Mtn Element for over a year without ever bleeding them yet and they are still working great. I did put on a new rotor and jagwire pads.
    LOVE THE RIDE!
  1. help and advice needed
    By karelson in forum General Discussion
    Last Post: 06-17-2013, 08:04 PM
  2. This or That - advice needed
    By highdelll in forum Off Camber (off topic)
    Last Post: 02-05-2013, 11:40 PM
  3. Advice needed
    By cigarlover in forum Endurance XC Racing
    Last Post: 11-10-2012, 03:41 PM
  4. Formula DHR 150 rear hub info needed
    By guim in forum Downhill - Freeride
    Last Post: 06-10-2012, 07:07 PM
  5. 1 x 10 advice needed
    By jtc1 in forum Cannondale
    Last Post: 04-01-2011, 01:50 PM
