    Formula R1 problem
    I have a Formula R1 rear brake that when I squeezed the lever, it doesn't retract back to it's original position. I have to move the lever manually in order to go back to it's proper position. It was bleeded 3 months ago, but it's seems like it has alot of sticktion.
    Does it need to be bleeded again or it's a warranty issue.
    used to be RipRoar
    Reputation: TraxFactory's Avatar
    Sep 1999
    Your best bet is to call these guys directly. http://formulabrakeusa.com/about-us/
    It could be something as simple as the lever bolts too tight or something requiring a bit more knowledge..
    Had the same issue a few months ago.
    Was a build up of dust between the interface of the lever and the master cylinder.
    Took the lever off, did a wipe down and light lube.
    Brought the levers back to a smooth action.
    thanks for the suggestions...will try it.
