Results 1 to 2 of 2
    Oct 2007
    Formula R1 and Airotors
    Hi All,
    I am considering getting some 2012 Formula R1s. Is anyone using them with Airotors? Also I will need to change out the hose (I am buying two fronts.) Should I go with the exceedingly expensive formula hose, or switch over to Goodridge or generic Jagwire?
    Reputation: splatworldwide's Avatar
    Aug 2005
    Go with the Goodridge hose. The lever feel is much firmer than the Formula hoses. This is most apparent with the longer rear hose. With the stock hoses, I could never get my front and back feeling the same. I'm much happier now that I switched to Goodridge.
    I haven't used Jagwire hoses, so I can't comment on them.
