Results 1 to 2 of 2
    Reputation: Surfas's Avatar
    Formula ORO Puro with ABS???
    Well I had XTR '03 brakes on my Blur LT and I need a more reliable and better performance brake set and change for Formula ORO Puro. But my front brake make a kind of vibration, I think is because the rotor when passing the pads with that undulation make this. Like a ABS system on the automobiles.
    Right know I only try the front brake because the rear are for changing for a 2007 model.
    Is it normal that type of vibrating, is like when I pull the levers the stopping isn't even stop more/stop less, and make that vibrates???
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    Check that the pads are not hitting the rotor "arms"... this could be causing the vibration...
