    Formula Oro Lever body - push rod pulled out
    I crashed onto my Oro K18 left hand side lever and managed to pull the push rod (I think that's what it's called, it's the metal rod that is attached to the lever blade that pushes into the lever internals) out. It is part #23 on the K18 exploded diagram on this page http://www.formulabrakeusa.com/?page_id=5.
    Does anyone know if this is fixeable and how to do it?
    Cheers.
    Also I'm running The Ones on my DH bike, and was wondering what the purpose of that little metal part that stops the levers hyper extending is (it's bolted to the lever blade with a little hex bolt)? It seems like it would pull the push rod out of the lever body if you crashed hard onto the lever, can I just remove this piece?
    Reputation: stretch169's Avatar
    That rod should just pop back in, my son has done this twice recently. I thought he broke it but he just backed out the adjustment screw to gain free play and popped it back in. The OROs really are a great design. I have Megas too but the lever is different than the ONE so I can't help you with the other question.
    Pivot Firebird, Tomac Snyper, KTM 250SX
    that happened to mine to once. Just pop it back in. I did have to do a bleed after
    Lead by my Lefty............... right down the trail, no brakes.
    EDIT: fixed now, cheers
