Results 1 to 7 of 7
    wab
    wab is offline
    Formula Oro K18: losing oil during bleed
    I am bleeding my Formula Oro K18 brakes. The manual says to connect the first syringe to the caliper port. However when I remove the port screw, oil is coming out quite quickly. This is not a problem as I am filling the system with new fluid anyway. But when the bleed is finished and I remove the syringe from the calliper I get quite a lot of fluid coming out again. It takes a few seconds of fiddling with the little O-ring and screw and in that time about 10 drops of oil have leaked from the calliper port. Is this normal and what can I do about it?
    Meh.
    Reputation: XSL_WiLL's Avatar
    Are you clamping both syringes before removal? Are you pushing fluid through after one syringe is already closed?
    Turn the caliper on its side.
    wab
    wab is offline
    I am not pushing any oil after disconnecting one syringe. I had not thought about clamping, as it's not in the manual. I will try that, and removing the caliper from the frame to turn it on it's side.
    Were you able to get your brakes working? I was thinking about bleeding my K18s soon, so I am picking up any tips I can.
    all day long
    Reputation: DickemDown's Avatar
    The bleed hole is the same as the Juicys which does have a clamp on it. I was having the same issue as you until I began to use my Juicy bleed kit. Laying your bike on the side will also help.
    Smokey, this is not 'Nam. This is bowling. There are rules.
    Industry Member
    Hi Guys,
    If you are having trouble with the bleed process please give us a call in the office. We can work through it step-by-step and figure out what you are doing incorrectly.
    Cheers,
    Chris Costello
    707.765.2770
    Formula Brake USA
    Guys,
    When you are doing a bleed job, and removing the syringes.... if it's the syringe on the caliper, lay your bike down, so the port where you screw /unscrew the syringe is pointing up, so that the caliper is at the highest point and acts like a cup for the fluid. Insert seal and screw. Then place the bike so that the port for the brake lever, where syringe # 2 is, is at the highest point, then remove fitting and syringe from the lever port.
    If you always make it so that the highest point in the whole brake system, caliper or lever is where you are adding and removing a syringe, you won't lose fluid from the system, maybe a drop or two from the syringes.
    Gravity and air bubbles are your friends, use them wisely. Gravity will always pull fluid down and air up, so remember that basic rule when bleeding your brakes..
