Results 1 to 5 of 5
    May 2005
    Formula One, which Goodridge kit fits?
    I'm trying to figure which Goodridge hose kit would fit Formula One brakes.
    On Goodridge site they are mentioning only B4s (kit #101) and this kit uses banjos on both ends. I seen one vendor listing #107 as compatible, anyone had experience with those?
    Thanks.
    I used to run tubes like you are, but then I got thorn in my wheel.
    Kit 109 fits formula the ones.If i remeber i had to used the original banjo bolt caliper end.
    Reputation: ScottW's Avatar
    Oct 2007
    Order them from Larry @ http://mtnhighcyclery.com/, that way you'll be sure to get the right stuff. Tell him you want the 109s for your The Ones and you're set.
    There are some Goodridge kits out there that are mis-labeled as 109s (they are actually 110s for post 2005 Juicy's)...so I learned the hard way...the lever end fitting was fine threaded verses coarse threaded (ala pre 2005 juicys, which is what the ones need). I returned 'em and called Larry.
    May 2005
    Larry the man
    Just sent him e-mail, since I'm waiting for few other things from him as well. Chainreaction prices seems nice but the picture of the kit doesn't match description. They are clearly posting fine-pitch bolts on the image.
