Results 1 to 2 of 2
    Mtbr
    Reputation: dbo43867's Avatar
    Formula K18 Piston Not Moving, Help?!
    Hi guys I have a one year old set of Formula K18 brakes. The rear brake one day started getting weaker and weaker and then the bike sat for about a week. When I came out when the lever touches the handlebar the rotor barely rubs the pads. I have attached a video of how little the piston moves at full lever extension. I cannot see nor did I see any leaks at all. Any idea what this could be? Thanks
    <embed width="440" height="420" type="application/x-shockwave-flash" src="http://v3.tinypic.com/player.swf?file=2rx8q6b&s=3">
    2008 Rig
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    Looks like you need to bleed. You mgiht not have seen any leaks but it doesn't mean a fresh bleed won't solve the problem.
    Check out my SportTracks plugins for some training aid software.
