Results 1 to 23 of 23
    Apr 2005
    Formula Brakes Guys!! Help
    hopefully i got your attention!, well i´m hours away from ordering my first set of formula brakes, i´m stoked!, i´m just having trouble choosing between k24´s or the bianco´s, particularly because of the brake lever...i know the bianco is supposed to have a longer lever but could you guys post two pictures, one of the bianco lever and then one of the k24 or whichever of the oro´s so that i can get a good look at the difference??? thanks in advance! looking forward to pinning it on formula´s!
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    Bianco has the shorter 1- finger lever and more aggressive sintered pads.
    K24 has the longer 2-finger lever and organic pads.
    Bianco Lever:
    Apr 2005
    thanks squeeky wheel. i actually regret posting this thread after taking a look at various threads that answered this and other questions that i had about formulas...BIANCO´S it is!!
    Industry Member
    Hey DHperu,
    I am glad you figured out your questions with a bit of research. I just want to let you know that the Bianco lever is actually slightly shorter than the K24 lever.
    If you still want those pics...let me know.
    Cheers,
    Chris Costello
    Formula Brake USA
    DNW
    DNW is offline
    Reputation: DNW's Avatar
    Mar 2006
    Not to hijack, but are parts on the Oro series interchangeable? Can you upgrade levers, hoses and hardware?
    Industry Member
    DNW,
    Yes, the parts you mention are interchangeable, as are most of the other parts on the brake.
    Cheers,
    Chris
    Apr 2005
    oh its shorter? so what is the difference between one finger braking on a 24k versus the bianco? is the feel diferent? do you get more leverage out of the bianco lever? i like one finger braking so i suppose the bianco is for me right?
    Industry Member
    DHperu,
    The lever blade on the Oro Bianco is thinner (not as tall) and is forged, making it stronger than the cast Oro K24 lever blade. In my opinion, the difference comes down to how thick of a lever blade you prefer, since the brakes are powerful enough to only use 1 finger anyway. That being said, most of our sponsored DH riders prefer the 1 finger blade.
    Cheers,
    Chris
    Baller/Biker
    Reputation: streetpro0323's Avatar
    k24 vs Puro
    Is there any reason other than the weight (& gold ) to purchase the puro over the k24? I'm ready to pull the trigger right now on a new set of brakes for my shiny new Ventana!! also whats the weight diffrence?
    Industry Member
    Streepro0323,
    Weight and bling factor are the main differences between the Oro K24 and Oro Puro. The weight savings total about 100g on a complete set up if you go with the Oro Puro. A 1/4lb savings ain't too shabby...especially when you consider that you are not sacrificing any power or performance with the lighter setup. However, the Oro K24 already come quite light at 398g with all the hardware and an IS adapter.
    Cheers,
    Chris
    DNW
    DNW is offline
    Mar 2006
    I just installed my new K24s yesterday, and put a couple local miles on them. Easy installation, VERY nice of Formula to include extra parts so you can immediately shorten the brake lines, which I did with no difficulty. It would be nice to include the bleed kit with the brakes, but that is minor.
    Construction and feel seem solid, much better than my Hayes El Camino. They also weigh 1/2 lb less for the setup (7" rear, 8" front). Perfomance (not even broken in) is already better than the El Caminos.
    Nice brakes so far!
    mjc
    mjc is offline
    Bianco blade on k24
    I just purchased a set of k24s for my five spot. I had been using hayes with some aftermarket shorter levers and have gotten used to single finger braking. Are there any decent short levers that will work with the K24's??
    Marty
    ride more, eat less
    Industry Member
    Marty,
    Bianco lever blades are available aftermarket and can be installed on a K24.
    Thanks,
    Chris
    Formula Brake USA
    Anyone know why Formula abandoned the magnesium calipers?
    Also, what do the Oro Puro IS adapters (with bolts) weigh?
    kabouterclan member
    Quote Originally Posted by eurorider
    I heard the brake fluid corroded the magnesium from the inside
    29er wannabe
    Reputation: yagimax's Avatar
    Mar 2005
    K24
    I've been using the K24's on my 29er for several weeks now and using one finger to stop instantly is not a problem.All I can say is that these are the perfect brakes. Super strong and no break in required.
    mjc
    mjc is offline
    Will the adaptor in the photo above work for K24 and Sramx9 (2007) shifters? I would love to cut the clutter.
    ride more, eat less
    Phil from San Diego
    Reputation: Prexus2005's Avatar
    Mar 2005
    Quote Originally Posted by mjc
    Yes. =) I have the same combo and it works great!
    Phil.
    mjc
    mjc is offline
    adaptor
    Can I ask where you go the adaptors?
    Marty
    ride more, eat less
    ups and downs
    You can get them here...
    Obsessed
    Reputation: santiago's Avatar
    Aug 2005
    I ordered mine from Larry @ MtnHighCyclery. He's a regular here on the forums using the handle "Ventanarama". You can PM him or email him. Check out http://mtnhighcyclery.com
    Confit de canard
    Phil from San Diego
    Mar 2005
    I think I got them also from Universalcycles or could have been JensonUSA... or PM Chris at Formula brakes and order it from him directly. =)
    Phil.
    Reputation: rockman's Avatar
    about 40 grams with two of the 4 bolts being titanium for 1 set. I have the Puros.
