Results 1 to 5 of 5
    Bite Me.
    Reputation: cutthroat's Avatar
    Formula Biancos Died - Ideas?
    I just finished swapping out the pads on my 2008 Formula Oro Biancos and took them for a ride to bed in the pads. Half way down a fairly steep grade I lost all power in the front brake - nothing, nada, gone. At the point of failure, I felt a little click or movement through the lever, almost like something gave way in the caliper, master cylinder, or lever body. When I got home I tried squeezing the brake lever with the rotor out of the caliper - there's no movement of the pads or pistons at all, although the lever still moves. When I replaced the pads, I cleaned everything with denatured alcohol, pressed the pistons all the way into the caliper body and bled off a little brake fluid to open up the calipers to fit the new pads - all according to spec. Any ideas what might be going on here - I called Formula but no answer - thanks.
    When I see an adult on a bicycle, I do not despair for the future of the human race. ~H.G. Wells
    wow....thats scary
    Reputation: vk45de's Avatar
    I doubt it's the caliper, or you'll be leaking. I'm guessing something in the MC gave. How does the lever feel compared to normal?
    Bite Me.
    Problem solved but it's still a mystery - I talked with Charlie at Formula (great CS by the way) and he suggested checking the lever attachment bolt and also the fluid levels. The bolt was fine - so no issue there. When I checked the fluid level it was definitely low - so I added some more and bled out some big air bubbles. At first there was no change- I'd squeeze the lever, it would travel a few mms but still no action at the caliper - all of a sudden I got another crunch or pop feel in the lever and everything works again. Maybe there was a big air bubble in the MC, or maybe some little piece of debris in the line? Not sure, but it works OK now - I plan on watching it though. Thanks for the replies.
    It is possible to introduce air past the seals when pushing pistons back in, or when they retract, but enough to fail? Something's weird here.
