Results 1 to 2 of 2
    Reputation: wickerman1's Avatar
    Formula B4 Gold's
    IS there any lever modulation adjustments on these brakes?
    (aka SS_MB-7)
    Reputation: 1speed_Mike's Avatar
    Quote Originally Posted by wickerman1
    No, the only lever adjustment is the screw which moves the lever in and out (relative to the bar) for reach adjustment. You can vary the lever-throw by removing the wheel/rotor and giving the lever a slight pull. This will move the pistons/pads closer to the rotor and will make the lever-throw very short.
    Ride Hard,
    Mike B. (MCM# 7.77)
    http://www.one-speed.com
  1. In Search of Formula B4 Gold Brake Adaptors
    By MMcG in forum Brake Time
    Last Post: 06-24-2005, 08:33 AM
  2. Formula B4 Pro failures ???
    By milliondollarhero in forum Brake Time
    Last Post: 03-14-2005, 01:46 PM
  3. '03 Formula B4 SL's - Light, But......
    By swalters in forum Weight Weenies
    Last Post: 05-29-2004, 03:51 PM
  4. 140mm Rear Rotor for '04 Formula B4 Pro +?
    By AZ-X in forum Brake Time
    Last Post: 04-19-2004, 03:28 AM
  5. Replies: 11
    Last Post: 03-25-2004, 07:50 AM
