Results 1 to 3 of 3
    formula adapter question
    Sorry for another adapter question but... I'm about to get a new front end (new fork, new rotor, new brake) and was wondering what I might need for set up. I'll be getting a 2010 Manitou Minute and will be putting on a Formula K24 with 180mm rotor. I'm assuming I'll need an adapter of some sort. What type will I need? Any specific ones better than others?
    Thanks in advance for your guidance.
    Jul 2003
    Just get a Formula 180mm post mount adapter. That should be all you'll need. Go with the Formula adapter though. While adapters all do the same thing, the contour, shape and size of the caliper can be an issue when trying to use an adapter from a different manufacturer. Unless someone chimes in that has actually used a different adapter with their K24s, go with the Formula adapter. That way you are 100% certain that it will work with your brakes with no issues.
    Good Dirt
    I just ordered a Fomula 180 post mount. Thanks for the help Squash.
