Results 1 to 3 of 3
    formula the 1 noise
    Hi all
    I have CUBE FRITZE with the a.m. brakes, they are doing a great job but my front brake making noise of pads/disc touching all the time when the speed increase, its not a matter of adjusment. they noise come and go loader and less loud with out any reasonable reason.
    the technition keep telling me that its normal behviure with bis discs??.....
    I have friends with big discs (not the one) but with out no noise problem.
    does any one faced such a thing.
    Reputation: mtbnozpikr's Avatar
    I guess this is a relatively common problem with disc brakes. There are a few things that could cause this sound: your caliper may not be centered, your rotor may not be true, your hub bearings may be worn/pitted, and your wheel may not be installed correctly. I used to own a set of the ones and loved them before I got rid of the bike. Good luck.
    2012 Intense M9
    2012 Pivot Mach 5.7 Carbon
    2008 Look 595
    2007 Custom Litespeed Sewanee
    Second Opinion
    Have another mechanic look at the brakes.
    My 'One's', make no such noise. But, I remember my S.Cruz Superlight had a crappy hub that was forged incorrectly and their was no cure until I changed my wheel. Some bike/wheels have weird harmonics that set up noise.
    Did your brakes always make noise or is this a new phenomenon?
    Cheers,
